Hi Jerry,
Can you rewrite your question in English for us to help? Thank you.
Hi Jerry,
Thank you. We received your following message:
[Acco4ding the circuit in the figure below, I want to know the function of DADP1, so I can omit it.
Acco4ding the circuit in the figure below, I want to know the function of DADP2, so I can omit it.]
This particular figure is used for applications where an auxiliary power source, such as a wall adapter, is used to power the device.
To make the MP8003A work stably with adapter power, one Schottky diode (DADP1) is required between the negative terminal of the adapter and VSS. DADP2 is used to block reverse current between the adapter and PSE power source. These cannot be omitted unless you do not plan to use a wall adapter.
Hi,Jerry,
MPS中文论坛也已上线,您可到中文论坛提问,由我们中国区的工程师为您解决问题:www.forum.monolithicpower.cn
