What will be the maximum switching frequency that MP6908 can run for both CCM and DCM mode? (eg, 100 kHz, 200 kHz and so on)
Is it suitable for low voltage inut CCM mode SR flyback converter? (eg, 10~32 Vdc and 15 V,1 A output and fs=200 kHz?)
Hello zinmin.kyaw1,
- MP6908 is good for applications less than 100kHz. If you are using high fsw then use the MP6908A/08S.
- Yes, it should be about to handle that voltage range.
Thank you,
Field Applications Engineer
