MP6543C SOx Pin NC Termination
I am only using outputs SOA and SOB on my MP6543C. How should I leave the SOC pin? Is it best to leave it floating or should I place a resistor divider on it anyway even though it’s not being measured?
The data sheet does not specify a design for unused SOx pins.
Thanks.
The typical application use case in this scenario would be for some 3-Phase Brushless DC Motor where all these SOX outputs would be used.
I suppose if the SOC output is being unused, this can be left floating. This would then lead me to ask what kind of motor are you using alongside the MP6543C?
We do have dual-half bridge and full bridge stages if you are still early in your design as well, but I suppose this would depend on the type of motors you are trying to drive.
Thanks Krishan. I am using just a normal three phase BLDC. I am reconstructing the third phase current measurement from the first two which is working well.
Understood, as long as the motor is being driven effectively and you are able to read currents accurately, this should be ok.
