Hi, there.
Motor drivers including MOSFETs heat up by switching to some degree while using on applications.
How can I calculate the power dissipation for PCB design in advance?
Kunihiro
Hi, there.
Kunihiro
Hello xyamada,
I apologize for the delay, I will try to get a response back to you in 2 days.
Thank you,
Is there a way to calculate or estimate switching losses, i.e. losses due to parasitic capacitances of the power-MOSFETs in the output stage?
Only parameter given in the datasheet is Rds_on, that is only part of the total losses.
