Hi, I am trying to use MP6538 predriver IC. I was wondering if there are any support documents for the eval board on the steps to hook up motor to the board and to evaluate the performance for specific PWM.
Regards
Pooja
Regards
Pooja
Hi Pooja,
Here is a link to the evaluation board on our website. It has a quick start guide for instructions on how to prepare the board. You can match inputs and outputs to your motor. Can you clarify what you mean by evaluating the performance for specific PWM?
Brendan Schoemehl
Field Applications Engineer
Hi…the EV6538-V-00A is an assessment board for the MP6538, a three-stage BLDC engine pre-driver. It works from a stock voltage of up to 100V. It is designed to drive 3 half extensions comprising of 6 N-channel Power MOSFETs. The rotor position data is given by the Hall sensors amassed in the engine and the driving control signals are produced by the outer regulator, like MCU, FPGA.
