Greetings,
I’m attempting to use an MP5035 as a load switch with high slew rate, as I am targeting a controlled rise of 12V over about 10µs. In my current breadboard setup I am using a 150pF capacitor on the DV/DT pin to achieve that, though the rise time is about 130µs. Switching to a 22pF slightly decreases that rise time by a couple microseconds.
I largely suspect it’s my selection of breadboard that is limiting my slew-rate, but I wanted to check to see if there is a limit on the MP5035 that I might have missed. Is there a minimum capacitance value for DV/DT that provides a max for slew rate? If so, is there a similar component that has faster slew rate capabilities?
Thank you,
Frank
