I am trying to using this power switch to control power to a device with a large amount of caps. What is the best method in calculating the Slew Rate so the switch doesn’t go into hiccup mode?
Right now, I have the power switch with Mode pin floating and DV/DT floating. Once I power on my device through the power switch. Power switch enters hiccup mode.
I don’t understand the datasheet where it mentions the calculations for DV/DT. Is there a better explanation elsewhere?
Thanks
