MP3921 control in linux system
Whether MP3921 has init code in linux system.
Hi jasperc,
What kind of init code you are mentioning here?
Adhish
Whether there is a coding guideline to MP3921 control I2c process.
Hi jasperc,
The MP3921 can work without I2C as well when you chose Automatic mode, if you want to use I2C semi-automatic mode/Manual mode can be used.
The I2C control is mentioned in the datasheet. Refer to page 21 to 24.
Adhish
