Hi there,
I want to use the MP3900 for my Boost supply. My Input is 12V and Output requirement is 28V. In the datasheet Output voltage is mentioned 25V everywhere but since it is adjustable, Can i adjust this for 28V. Or are there any limitations with this requirement?
Priyanka
Hey @pkumari ,
DS references 25Vout a bunch since that is an application we believe to be most common. This part is meant for applications where Vout is less than 30V, so 28V should be fine.
We also have evaluation boards for you to order and play around with to make sure this part is the right fit for your application!
Just make sure to not exceed the Absolute Maximum Ratings listed on pg 2.
Jonathan Hidalgo
