Is the APD current monitoring/mirror function of MP3430 optional? What is the best way to configure these pins with minimal external components?
I am using this boost converter for an application circuit on how to power our MEMS switch drivers. Output is 90V, < 500mA max. See below for my draft circuit diagram, is this valid?
Your application will not be possible with this design. For 90V 500mA output, you will need at least 13.6A input. This exceeds the part’s 1.3A max switch current limit.
