REF: MP3362. What is the maximum supported voltage on the DIM pin? The data sheet does not specify.
Thank you.
Thank you.
Hi Sparker,
Please see the following image
It is recommended to use voltages that satisfy the low and high hystersis while not going over the absolute limit.
One of our applications does not require dimming. Accordingly, what value pull up resistor is required to enable the chip at the dim pin?
