Hello
In the datasheet it is stated that the accuracy (e.g. in FLASH mode) is +/-7% and step is 7.84mA
is this accuracy defined for the full range of operating temperature?
what is the current repeatability between power on off cycles?
thanks
Hello
thanks
This accuracy should be defined for the full range of the operating temps. I would encourage you to observe how repeatable the errors are at different temps depending on your use case with an evaluation board.
Here is a link to that if you are interested:
EV3336-C-00A | Dual-Channel Flash LED Driver With 2A/Ch and I2C Interface Evaluation Board | MPS
