What are the main technical and functional differences between these two controllers?
What are the recommended input voltage ranges (VIN) for supplying the multiphase controller itself and the external Intelli-Phase™ power stages?
Can the controller and power stages be supplied directly from the same input voltage source? If so, what is the recommended VIN range for the overall system?
What is the supported output voltage range (VOUT) for each controller, and are there any specific limitations depending on the selected power stages?
Thank you for your help.
Best regards,
