I got a quote from distributor for MP2853GU controllers but they say they have MP2853GU-0017-Z version. “0017” part of the code is about register settings but there is not any information about it in the datasheet.
Can we learn register settings of “0017” part?
Thanks in advance.
Hello cemil.urgup,
Thank you for contacting the MPS Forum. I have seen your question and will try to get an answer as soon as possible.
Thank you,
Hello cemil.urgup,
For the MP2853 products, they are named as MP2853GU-xxxx. The “xxxx” is a configuration identifier for the register settings stored in the EEPROM. The part should operate the same as any other MP2853.
Thank you,
