how do i program the OTP of certain register?
Does regular writing to the register consider OTP programming? is there a specific way to program OTP memory?
Will the register value be reset when powered off and powered on again?
The registers are reset when power-on-reset. Is it possible to store the registers after one write? Because in my application I’m using 1s configuration and LDO on the battery terminal with 5.5V max input. When I try to charge discharged lipo battery(0V because of the protection circuit), MP2760 outputs 2s voltage to the battery terminals, which burns my LDO.
