I see the evaluation board has a GUI for programming the MP2723, but I guess the registers are reset on a power cycle. There is the register information in the datasheet, but is there any API/firmware/driver for use in C++/C or otherwise that would allow to easily adjust the parameters via a microcontroller host (as opposed to a Windows machine)? If not are there any charger chips out there that have such an API to speed up design time?
Hi chirstopher.buckley,
I’m looking into this. Will get back to you asap.
Cindy
Hi christopher.buckley,
We do not have any API/firmware/driver for any of our MPS chargers. Apologies for the inconvenience.
The MP2723 uses an I2C-compatible interface to set the charging parameters and instantaneously
report the device status.
Cindy
