We are using MP2722 IC. In that we have tried as per the datasheet register setting enabled the Boost with DRP
First time
The chg int 12H - 06 when Type C charging is not connected
chg int 12H -76 when Type C charging is connected
Second time onwards
chg int 12H -06 when Type C charging is connected
So the Interrupt is not working after removing type c and connected.
Regards
Balakrishna
Hello krishna.varkala,
please upload screenshot of register values for each portion described for better assistance.
Hello edurado,
Thank you for the replay. The below are the screenshots of the same.
1st attempt
The charger is disconnected
The charger is connected
2nd attempt onwards, The charger connected also reg12h is not updating
The charger is connected again
Balakrishna
Looking into this will update you when I have more information
Hello eduardo.
Have you received the update/more information?
Balakrishna
This supports boosting from the battery to the IN pin. Not from IN pin to the battery.
What interrupt are you expecting?
