Can MP2722 be used with LTO18650 ?
specs: https://files.gwl.eu/inc/_doc/attach/StoItem/7015/GWL_LTO1865_Rechargeable.pdf
Hi ,
What is the application of your design?
MP2772 battery regulation voltage threshold is ~4.2V. I see that the LTO cell is 2.8V max per cell. This IC will not be compatible with this battery.
Nouman
Thanks for your quick answer. Indeed, with access to datasheets now, we also concluded that MP2722 does not feet li-titanate chemistry. We are looking for ic to simplify our line of single cell li-ion/lipo iot devices. We are also testing li-tatanate in our lab and how it may benefit our customers.
Our charger ICs are optimal for the Li-ion/ Li-Po battery chemistries. If you have not already - here is a link to the single cell IC devices. You may use the parametrized search to find the best suitable charger. You may also let us know if there any specific on the project or system requirements and we will do our best to provide a recommendation.
1 Series Cell Chargers - Chargers - Battery Management - Products (monolithicpower.com)
Kind Regards,
Nouman
