The MP2720 has several registers that can be OTP programmed for changed default values but
nowhere is it described how/where this can be done…anybody knows?
Hi Jorgen,
Generally for OTP parts, the one write is taken up by the default. Configuration settings can be changed as many times, but power cycling will revert the settings back to default. For the registers that are OTP-configurable, you can apply for a 4 digit suffix code that is specific to your application. This will use the one write to your configuration settings. For more information, please contact MPS NOW Remote Support - Support.
Yu
