I am trying to integrate MP2667 charging circuit in a smart device. Is it possible to identify the battery percentage level using this ic? Once it is fully charged the user will remove USb from charging and need to charge again when the battery level goes down, For this I am planning to connect a RGB led and to blink the led once when battery level goes down so the user get alert to charge it again. Is it possible using this MP2667 IC
Hello jayasreejayaraj97,
It is not possible to get battery percentage from this device. Please check out our chargers with a built in ADC or get separate device for monitoring the battery,
Thank you,
Field Applications Engineer
