Hi
I am integrating MP2617HGL-P into my electronics and wanted to check for an application note or a relevant example of layout for this device. Not used such complicated IC before so would be nice to lay it out properly too.
Thanks
Hi
Thanks
Hi Dainius,
Thank you for utilizing the MPS Technical Forum,
You may refer to the Layout Guideline in the datasheet on pg 29.
We also have EVB for this device, it might assist you with PCB layout. ( here is the link: EV2617H )
Nouman
Hi Nouman,
This is great. Thank you for the information. I will use this as a reference. Thank you.
