Hi all,
I want to use this chip in buck mode to control an LED but I would really prefer it if I could keep the signal and the power GNDs separate, unlike the application circuit described in the datasheet (Fig.3, p.13).
Would something like the following work?
And if yes, should I include the 100ohm resistor on the INGND pin like when you use the chip in boost mode (Fig.4, p.13)?
