a few questions on MP1605 and MP2141 synchronous step-down converters. Their specs seem nearly identical, with MP1605 curves simply extended beyond the 1A limit of the MP2141.
- are they the same silicon, with the 1605 simply a binned / tested batch ?
- the 2141 has a better continuous power dissipation spec (1.5W instead of 1W), but only because it’s tested on the EV2141N-TF-00A evaluation kit with probably more copper pours than the standard JESD51-7 ? The difference is quite surprising.
- In the 2141 thermal resistance specs, theta-Junction-to-case is listed as 50 C/W on that EV2141 eval kit, but 60 C/W on the JESD board. Can you explain why the junction-to-case resistance would change by simply using a different layout ? I always understood the theta-JC spec to be layout-independant…
Thanks for clarifying,
Chris
