I’m using the mEZDPD3603A-0001 at his default configuration to drive load of 0.5-1.5A @ 5V.
I measured the output voltage and it shows 4.78V even that at the datasheet it says that the minimum voltage should be 4.95V at maximum load.
Do you have any suggestions?
BR
Yuval
Hi yuvalm,
Thanks for your question.
Can you provide a schematic of how exactly you are connecting the part? Showing the voltages applied.
What are you using to measure the output?
Cindy
