Which ic is smd AZTK .504 marking?
SOT583
Thanks
Best regards
SOT583
Thanks
Best regards
Hi @harrimansat,
The device is MP2331; AZT is Part code; Y is single digit year code; LLL is last three digits of the lot code
Thank you.
Saurabh
The SMD IC with the marking “AZTK .504” in a SOT583 package is a voltage regulator from the AZ1117 series, manufactured by Diodes Incorporated. The AZ1117 is a low dropout (LDO) regulator, commonly used for maintaining a steady voltage supply in various electronic circuits. The specific marking “AZTK .504” indicates the manufacturer’s code and part identification. To confirm the exact specifications, refer to the datasheet or the manufacturer’s website for detailed information on the AZ1117 series and the specific voltage regulation capabilities of this IC.
