I found MP2113DD-LF-Z finding marking different from datasheet. It should be MP2113DS , but I’ve found R3…
Any official document relating it?
Hello purchasing4,
Welcome to the MPS Technical Forum! Please see the highlighted section below from Pg. 2 of the MP2113 datasheet. This device is also marked NRFND and I would recommend looking at the MP2152 if you need a replacement.
thank you for your prompt reply. I’ve received markign R3AK instead of MP2113DS.
Do you have info about marking R3AK? I’ve found these links about case and mrking, but I don’t understand why datasheet advices MP2113DS as marking
thank you in advance
Hi purchasing4,
Can you please upload a clear picture of the top marking on the IC? A couple shots of the device package from different angles would be helpful too. I will then confirm the top marking for the MP2113.
