Can you please recommend 1 or 2 (or more) specific part numbers that would be best suited for driving an LED backlight in an LCD with the following specs / LED strings configuration?
They are going to want to know your Vin, If you have 24V to work with then a buck type converter would work, if you have 5 V to work with then a boost type converter.
Excellent point @jshannon. Thanks very much for pointing that out and saving me some time.
We will need a boost converter. Vin will be supplied by either a 5V switching regulator or directly from LiON batteries at approximately 3 - 4.2V.
The closest part that would match your specification is MPQ3387L-AEC1.
Datasheet: https://www.monolithicpower.com/en/documentview/productdocument/index/version/2/document_type/Datasheet/lang/en/sku/MPQ3387L-AEC1/document_id/3845/
Let us know if you have any question.
Yash Shah
