Hi
Is MPM54304 supported by Virtual Bench Pro 4.0 ?
Thanks a lot
Ali
Hi
Thanks a lot
Ali
Hi Ali,
Yes it is, are you experiencing problems connecting to it?
Best regards,
Nicolas
Hello Nicolas,
Not yet. I am thinking to use MPM54304 for my next design. I will let you know if I face any problem with Bench when configuring MPM54304.
By the way, in MPM54304 datasheet,
Table 3 says buck 2 has 3.3V as default/ predefined output.
However figure 4 shows buck 4 has 3.3V as default/ predefined output.
Which one is correct ? I am thinking to use 3.3V as a pullup voltage on I2C bus.
What are the default/ predefined output voltages on all outputs?
Regards
Ali
