Hi there
I would like to use MP4569. Can you provide a spice model or data which helps to calculate an input filter to pass emi-testing?
Thanks and best regards
Patrik
We do not have a spice model as of now. However, few things you can follow to improve EMI:
- Please use small and flat coil inductor.
- Make SW area is smaller
- suppress SW spike by adding a snubber circuit.
- Use pi-filters.
The layout of the PCB plays a vital role in EMI noise. Please follow the guidelines given in the DS.
We have a lot of articles and webinars related to EMI which can be found here.
I hope this helps.
Saurabh
Hi Saurabh
Thank you for your answer. I am looking for data to calculate the correct values of the Pi filter. I will search the attached links. If you have a direct guide regarding the pi filters, that would be great.
Patrik
