Can you please give common mode field rejection ratio (CMFRR) of the MCS1803 and MCS1806 ? Do you recomend to use a shield for MCS1803 and MCS1806 Hall current sensors ?
Thank you very much.
Xiaofeng Xu
Xiaofeng Xu
Hello @x.xu ,
Since the hall array is differential, it will be immune to strong magnetic fields. There should be no need for a shield.
We also have an evaluation board to help you test out the part and see how it behaves!
Jonathan Hidalgo
