The documentation available online says “There is not a simple relationship between tOC and CTIMER. Select CTIMER based on experimental results”. Can you please provide at least a starting value for C_timer and R_timer? Thanks.
Hi Sudhanva,
Kindly refer to the equations and the design circuit example that can be found towards the end of the datasheet.
Yu
