I plan to use MP9486 to output 3.3V to MCU, but I have searched for relevant information and have not found any information about the resistance values of R1 and R2. There is a formula R1=(Vout Vfb) * R2/VFb
But the information only states that when outputting 5VDC, Vfb=0.2V
What voltage should Vfb be when I want to output 3.3VDC?
Hi zhenglin,
Choose R1 to be 240k. Use the equation (1) in the datasheet to calculate R2. R2 should be, 15.5kOhms. Now double checking that Vfb is 0.2V, you can use a resistor divider equation:
Vfb = Vout * (R2 / (R1+ R2)) which gives around 0.19999V
