Hi, for MP5022C output cap,is there any way to caculate the vaule. cause the board space is limited, and the reference cap is 470u , can we use <470u cap? and what’s the relationship about output cap value and the output current.
The typical performance characteristics were taken with the 470uF output capacitor.
I believe it is being used for output stability.
If you use an output capacitance lower than that, the performance may differ than what is shown in the data sheet.
I recommend using the 470uF capacitor as shown in the data sheet.
I hope this helps.
Eliza
hi Eliza,
you not clearly know my question. if the output current is 5A, should still use 470u CAP?
Yes, it should be fine to use the 470u cap for 5A output.
Eliza
