HFC0100- Quasi Resonant Controller
Can this controller be used for Hv applications (Output voltage of 12kV, 1mA)?
Welcome to the forum. That is a very large output voltage requirement, to achieve your desired output; careful transformer design would be needed. I would recommend simulating the HFC0100 to determine if it will be well suited for your application. You can find our MPSmart Simulation tool here:
MPSmart | Design Tools | MPS | Monolithic Power Systems
If you find the part does not fit your needs, you can use our AC-DC quick search tool to help you find other products that may suit your application.
AC-DC | MPS | Monolithic Power Systems
