EVL2643-R-00A – Continuous Audible Noise in Manual Boost Mode During Validation
Dear MPS Support Team,
I am currently validating the EVL2643-R-00A Active Cell Balancer Evaluation Kit in Manual Control Mode and would like your guidance on an issue observed during the boost-balancing operation.
Test Setup:
  • Evaluation Board: EVL2643-R-00A
  • Battery Configuration: Two 18650 Li-ion cells
  • Cell 1 Voltage (Lower Cell): 3.64 V
  • Cell 2 Voltage (Upper Cell): 3.93 V
Buck Mode Test:
  • CLx-MODEx Jumper: Open
  • ENx-Sx-MODEx Jumper: Left in Manual Mode position
  • Result: Buck balancing operates correctly, and charge transfer appears normal.
Boost Mode Test:
  • CLx-MODEx Jumper: Installed (Closed)
  • Result: A continuous audible sound (high-frequency/whining noise) is generated from the evaluation board immediately after enabling boost mode.
My Questions:
  1. Is the observed continuous sound normal during boost-balancing operation on the EVL2643-R-00A?
  2. Could this sound indicate inductor saturation, unstable switching, incorrect jumper configuration, insufficient input/output capacitance, or another issue?
  3. Will this condition prevent or degrade boost-balancing operation?
  4. Are there any recommended checks to verify proper boost-mode operation?
  5. Could the use of only two cells instead of a complete 5-cell stack affect boost-mode behavior on the evaluation board?
  6. Are there any known issues or recommended jumper settings for manual boost-mode validation?
According to the EVL2643-R-00A quick-start guide, boost mode is selected by installing the CLx-MODEx jumper, while buck mode is selected by removing the jumper. My configuration follows this procedure; therefore, I would appreciate any guidance on the source of the audible noise and the recommended troubleshooting steps.
Thank you for your support.
Pratyay Maity
