I am designing a product and I want to use EV6004-Q-00A as a module in my design, but I need to have the cad file or a picture which indicate spacing between the edges and connector, the pitch of the connector … etc.
if the cad file which contain this information is available, it will be better to have it to import it directly in Altium designer.
Thanks for your reply
the datasheet of MCP6004 contains the dimensions of the IC itself and I want to use the module not the IC
I checked EV6004-Q-00A datasheet and I found only the dimension of the board as L x W x H and this is not what I am searching for as I described in the main topic.
