Dear Team,
We are using MPM54304GMN-0003 in out power supply design.
I have a doubt in above part number. in the datasheet. for 0003, it’s showing buck 3 and 4 is paralleled. So can’t we use it separately. ?
I am no expert but, any suffix number says it’s a factory configuration u can change it any time
Yes u can use separately u need to reconfigure via I2C and save to MTP
Hi @vkj
Yes, you use it separately as well. however, it would be limited by the current mentioned in the DS. if you need more current, you’ll have use it in parallel format as shown in fig; 18 pg 41 of datasheet.
The suffix code is various programmed configuration and can be changed two times. (refer Pg 20)
I hope this helps.
Saurabh
