MPM3833C or similar converter can sink current from output to input ? We have an application with a load which voltage higher than the output voltage of the converter, the current must continue to flow at the opposite direction.
Hello marc.girard,
Thank you for contacting the MPS Forum. I have seen your question and will try to get an answer as soon as possible.
Thank you,
Hello marc.girard,
This device can not do current sinking,
Thank you,
