while referring to the data-sheet of MP44010 for designing a Boost PFC circuit I find difficulty in calculating the value of components like inductor. I planned to make the design example circuit but there is n0 part number available to purchase the components, so kindly provide me with necessary instructions to design a PFC circuit using MP44010. I will be more happy if some one gives me the calculation for the example design on the data-sheet. I am attaching the example circuit provided with the data-sheet
Hello @igniteprojectshardwa ,
Under “Design Resources”, the XLSX is a zip folder containing two excel sheets that will help with design! One will help if you simply want to design a flyback with high PFC and dual outputs, the other will help with your boost PFC circuit!
Jonathan Hidalgo
thank you for your response
