Sensors bandwith
Why should I reduce bandwidth for a current sensor?
Are there any software tricks to achieve good resolution vs. bandwidth?
Thanks!
Hi Pawel,
there are two major issues that can be solved by reducing the bandwidth:
  1. The ADC processing the signal has a lower sample rate than 2 x the bandwidth. This can cause Anti Aliasing Errors.
    The ADC input signal needs to be lower in bandwidth than the sample rate.
  2. More bandwidth brings more noise: if bandwidth is not needed but less noise appreciated: you can reduce noise by reducing bandwidth.
You are welcome!
