I use MTP54304 kit with virtual Bench Pro 4.0 to make evaluation.
The component works correctly. When I want to program the values in the MTP, I have a message ’ Writing ROM limitation exceeded, failed to write ROM.
There is a field in the software that indicates 0 Remaining write cycle in NVM.
I don’t remember to have the same in the lasted software Version.
Where does this limitation come from?
