Hello
I want to use MPM3632C with 0.8V output.
What values should I use for R1 and R2 to connect to FB pin?
(1) R1:0ohm,R2:open
(2) R1:47Kohm,R2:open
Or is it other value than this?
Best Regards
Hello
(1) R1:0ohm,R2:open
Best Regards
You can go with the first option. As the feedback voltage is 0.8V you don’t need a voltage divider for 0.8V output.
Yash Shah
Hello, Mr.Yash
I understood.
Thank you for your answer.
ptenk
