Datasheet indicates the following:
Just checking to see if this is a typo. I assume the JEITA NTC_TYPE is the default (1).
Hi willbond,
I will check to confirm the default setting for this register.
Hi willbond,
I can confirm that this is a typo and the sentence should read “This bit is set to 1 by default.” JEITA is the default NTC type for this device. Thank you!
